Hi @tom.geurts,
The two ways of debugging an experience created in ZapWorks Studio are:
- Launching into Zappar desktop and clicking on the setting cog. This will bring up the developer tools, where you can see a live console on runtime and any potential errors.
- Sometimes the Zappar for desktop debugger isn’t quite enough. As you have explained you can also use Google developer tools to debug your experience. Here are some steps below to help set this up.
** Please not, this is for Android only.
- First make sure that your device has developer mode enabled. For most android devices this is activated by going to settings → About Phone → Software Information and then tapping Build Number several times. If that doesn’t work, Google’ll know.
- Inside Developer Options tap USB debugging . Your device may ask you to confirm this.
- Plug your device into your laptop
- Go to
chrome://inspect
in chrome
- Tap Allow USB Debugging again if it comes up on your device
- Open Zappar
- Tap Inspect, and enjoy your USB debugging capabilities
At the moment there is no way to debug on a live preview window. You must first preview/publish the project. This not as bad as it sounds because with the speed of our instant preview/publishing, you can be debugging in seconds.
I will pass on the feature request of having a live preview and live debugging console to the platform team and see what they say.
