Issue:
I seem to be having problems getting the image training via the CLI to work.
I installed the CLI just as described in the documentation with:
npm i -g @zappar/zapworks-cli
I can run commands like zapworks serve
I get the following error.
Training the image - this may take a few moments...
TypeError: Failed to parse URL from /usr/lib/node_modules/@zappar/zapworks-cli/node_modules/@zappar/imagetraining/lib/ImageTraining.wasm
/usr/lib/node_modules/@zappar/zapworks-cli/node_modules/@zappar/imagetraining/lib/ImageTraining_node.js:48
throw ex;
RuntimeError: abort(TypeError: Failed to parse URL from /usr/lib/node_modules/@zappar/zapworks-cli/node_modules/@zappar/imagetraining/lib/ImageTraining.wasm). Build with -s ASSERTIONS=1 for more info.
at process.abort (/usr/lib/node_modules/@zappar/zapworks-cli/node_modules/@zappar/imagetraining/lib/ImageTraining_node.js:288:145)
at process.emit (node:events:513:28)
at emit (node:internal/process/promises:150:20)
at processPromiseRejections (node:internal/process/promises:284:27)
at process.processTicksAndRejections (node:internal/process/task_queues:96:32)
Node.js v19.1.0
I also tried the beta version with the same result.
What am I missing to make this work? The documentation seems pretty straight forward and I couldn’t find anything on this forum about this either, but two of my devices (Linux and MacOS) are having the same issue.
Thank you for your help.
