Is it possible to change the image tracking target source from a database call?
Have you tried this @stevesanerd
@George
@George
This one I’m thinking no.
ZapWorks needs to train the image so it’s not just an image anymore.
But you can save the zpt file (IE … Tracking-Image-Example.jpg.zpt (363.4 KB) )
So if you pretrain an image and then load the zpt file.???
@George ???
Hi @chatflicker and @stevesanerd,
Great question.
It’s not something I’ve personally tried but I don’t see why it wouldn’t be possible! As you say, the image would need to be trained and a .zpt file, you can do this in Studio or using the CLI.
The only issue you might run into is changing the source of the target dynamically but definitely give it a go!
Hiya,
Any luck with this? I have all my image trackers trained in Studio, would like to switch between them based on parameters but cant seem to do it via scripting.
Any help will be much appreciated, thanks!
