Can you move object position/rotation/scale together?
Hello guys , Im Ikram fairly new to zapwork studios.
How do i move multiple objects together? i can only select object 1 by 1 to move them,
is there anyway i can make a group? or use null object for these objects?
thank you
Hi @ikramandhakim,
Thanks for the question.
You can add a group to the Hierarchy with all the content you want to update together and then change the transform properties of that group.
or
You can set objects relative to another, meaning when one object’s transform properties are changed, the other will also update based on that value.
I hope this helps.
helps a lot thank you george!
