New computer! I’ve installed git but I’m still getting a “git not installed” message when I try to add the Zapper package (have tried the manifest.json method too). How do I tell unity the git is there?!
Hello @jonathanbehr
Welcome to the forum.
Make sure your system knows where the git is installed. To check, simply open your terminal and type git --version
. If the terminal says the command is not recognized then you would need to update your environment path, which can vary depending upon your OS. A bit of online search should help.
Once its set in your system’s environment, Unity should be able to pull the package.
Best,
