Hi I am creating a WebAR app using ZapWorks studio and have run into an issue where my camera feed freezes a few frames after the unlocking animation completes, I have experienced this on an iPad Pro which is using iOS 14.2, I have tested this on an iPhone running 14.2 and another running 13.5 and all seems fine, I have even created a blank test project just incase it was a bug I introduced but even this freezes a few frames after launching.
I have noticed if I press the menu button on the toolbar and then close the menu that the camera updates the frame and then freezes again. I can also tell that the app is not completely crashing as I tested this by auto starting the sequence through code rather than on detecting an image tracker and I was able to get the entire way through to the end of the experience so it just seems to be that the camera is not working. Any help with this would be greatly appreciated I am unable to tell if this is a problem on earlier iPad iOS versions as this is the only iPad I currently have access to.
Thanks in advance
