Hi again… SO here is my new challenge that I’ve been playing with.
I am busy with a flyer to try and see if I can have a few different videos playing, depending on what button is pressed. On this one, I have 3 videos that are supposed to fly in from the bottom and play, depending on what button is pressed - the first one works. - thanks to previous help from @destery
However, I’m not sure how to add the other two videos (Cheetahs and Cape cobra) so that they play on the same plane and immediately as the button is pressed. Also, if the one video that works (heroes) is busy playing, I’d like it to happen that if the same button is pressed again, it then starts again from beginning … make sense??
Would appreciate ANY help on this - I’ve attached a link to the the ZZP file, as it’s a bit too big to uplaod here - 51MB and maximum is 50MB. @destery perhaps
Tx in advance for any advice …
