I am curious on the best way to build the experience. We have a large physical model (multiple meters across) that we want to overlay content using Zappar. Think something like museum or educational experience. I want to create a single experience, but it doesn’t need to be linked. Instead it needs to properly orient the experience based on the side of the model you are on. If you scan on the North side the scan point is the origin and the experience is moved South. Scan the South side the scan point is the origin and the experience is moved North.
I am currently using Extended Tracking due to the size and the inability to keep the scan code in view. I want to build the experience and interaction as a single experience, but use the different zap codes to orient based on the initial scan.
I was thinking deep linking, but would that would with Extended tracking? I was also thinking about saving the experience as a zpp and loading it into the coded experience, but need to make sure features like raycasting and touch interaction are working.
Any input would be appreciated. Thanks.
-Eric
