Hi, I have used Studio to load a photosphere in my cardboard headset once the zapcode is scanned. Can someone please give me an example of how to easily change the displayed photosphere so that I can transition through a series of images. Thanks!
Iâm not sure if youâre familiar with this tutorial:
https://docs.zap.works/studio/tutorials/controllers-and-states/#a9-10-activating-a-state
But basically I would create states that change the material properties of the Photo Sphere(image 1 to image 2)
Weâve put together a little experience to show you a way to switch from one photo sphere to another in AR and VR modes. You can download the corresponding zpp file here.
In this project, weâve used two photo spheres (but feel free to use as many as you want!). Within each photo sphere, weâve inserted a plane (the red âTapâ button) and a raycaster, which tracks the direction in which the user is looking. Weâve âhighlightedâ the raycaster by using a target image. After launching the experience, the user can then switch from one photo sphere to the other by positioning the raycaster target onto the âTapâ button and -not or- tapping this button.
How does this work in Studio?
Weâve created a group called âSpheresâ made up of two photo spheres âPhoto Sphere1â and âPhoto Sphere2â, and a button per sphere.
Each sphere has a default size of [1, 1, 1]. Weâve chosen to place the center of the first photo sphere at [0, 0, 0] and the center of the other one at [3, 0, 0]. This way, we know that the two spheres do not intersect each other. (Please, note that from here Iâll call the âposition of the sphere centerâ âposition of the sphereâ to keep in simple.)
We wanted the camera view to move from the center of one sphere to the center of the other when the user presses a âTapâ button. Thatâs why weâve used one controller called âsphere_transitionâ with two states âsphere 1â and âsphere 2â. Each controller is associated with a specific position of the âSpheresâ group. (Feel free to read the Controllers and States article for more information.)
We have set the states as indicated below:
- If a user sees the inside of âPhoto Sphere1â and taps on the button => they should see the inside of âPhoto Sphere2â. This means that âPhoto Sphere2â needs to match the position of the camera view, which is currently matched by âPhoto Sphere1â.
The two photo spheres are inside the âSpheresâ group. Itâs important to understand that, to switch from one sphere to the other, we need the âSpheresâ group to move while we keep the user/camera view at its position [0, 0, 0].
Initially, within the âSpheresâ group, âPhoto Sphere1â is centered in [0, 0, 0] and âPhoto Sphere 2â in [3, 0, 0]. To move âPhoto Sphere1â out of the camera view and make âPhoto Sphere2â match the position of the camera view ([0, 0, 0]), the âSpheresâ group needs to be moved from -3 along the X axis. Thatâs what the âsphere 2â state does. As a result, âPhoto Sphere1â is then centered in [-3, 0, 0] and âPhoto Sphere2â in [0, 0, 0].
- Whereas if the user taps the button when in âPhoto Sphere2â, the âSpheresâ group needs to be moved back to its original position with âPhoto Sphere1â in [0, 0, 0] and âPhoto Sphere2â in [3, 0, 0]. Thatâs what the âsphere 1â state does.
Please, note that, in the pictures above, Iâve placed the âSpheresâ group below a tracking image âcircle-visual.zptâ node, so that you can observe how the spheres are positioned in the coordinate system. To position the camera view back inside one of the spheres, youâll need to move the âSpheresâ group below the âattitudeOrientâ node, as you can see below.
I hope this helps but if you have any questions, feel free to ask!
Margaux
Weâve created a new version of the project. You can download the corresponding zpp file: here.
Description of the new version of the experience:
The experience now starts in traditional (non VR) view. In this view, when you tap on a red button, it will move from a sphere to the next sphere (the crosshair has been removed to avoid confusion).
In the traditional view, weâve added a button so that you can switch from this view (Headset mode not activated) to VR view (Headset mode activated). When in the VR view, the crosshair will need to be pointing at the red button when you tap on the screen so that you can navigate from one sphere to the other.
Updates made in the Studio project:
Weâve added a black button (VR_switchbutton.png) to switch from the traditional view to the VR view.
Weâve created a mode_controls controller with 2 states:
- headset mode off as the default state, as we now want to start with the traditional view. Within this controller, the button to switch to headset mode is enabled and visible, the raycasters are disabled and the crosshair (raycaster_target) is not visible.
- headset mode on: the button to switch to headset mode is disabled and invisible, the raycasters are enabled and the crosshair (raycaster_target) is visible.
The headset mode off state is activated when the experience is launched (as itâs been set up as the default state) and in the headset Managerâs headsetleave() script (when the user leaves the VR view).
The headset mode on is activated in the headset Managerâs headsetenter() script (when the headset mode is launched).
- Weâve added a pointerdown() script under each of the two spheresâ button switch. Thus, when in the traditional view the user taps on a red button, it moves to the other sphere.
Best wishes
Margaux
Hello, i just tried it, in the Vr mode, i can not navigate, to go from the first vr to the other .
is there any thing i need to add in the Vr mode, to have the ability to navigate from first panorama to the other ?
Hi Elias,
As we received your questions through support as well, weâve replied there.
Best wishes,
Margaux
This is fantastic, and amusingly enough /almost/ exactly what I wanted. I canât wait to give it a try actually! The question I have however is just setting up buttons for each sphere. I actually have made a little silly walk around zap that lets you move around from sphere to sphere. I did what the first user suggested, change materials on the sphere. However, I came across the problem of âbuttons.â If I change a sphere, the same buttons are there. Iâve worked around this by turning buttons on or off depending on the sphere materials. If I move the spheres⌠I feel like the buttons from the previous sphere will still be there if I look in its directions. This is not desirable either.
My current example
Weâre glad to hear you found here what you were looking for!
Could you please send us the zpp file of your project so that we can take a look and point you in the right direction?
Many thanks,
Margaux
Hello, Iâm am new to Zapworks, have a gizilion of ideas⌠and Iâm preparing some âdemosâ to present to potential clients⌠I have a gizilion of questions as well LOL!!!
First off, thx for your help and tuts, they are really helpfulâŚ
I have a couple of questions regarding this particular projectâŚ
I canât seem to understand the raycaster, where it is in the project, and what it does exactlyâŚ
If I understand correctly, if I have multiple images, I need to create multiple sphere, and controller states, correct?
How do you manage to get both images the point in the right direction⌠My asking is that I tried to add the Headset manager to your 360 tutorial, and the images where pointing in different directions.
My headset does not have a button (Iâm using a Homido), so can I get the triggers to work by looking at the target an X amount a milliseconds?
And lastly, can I use portion, or certain areas of the images to trigger AR (ex. as you look around, different elements gets animated, or videos starts playing in picture frames on the wallâŚ
Thank you in advance for your help!!
regards,
Marc .
Hi Marc,
Thanks for letting us know you find the documentation and tutorials helpful!
To answer your questions:
Thatâs correct. Considering the project posted above, you would need one photosphere per image and one controllerâs state per photosphere.
To make sure the user is presented with a consistent view (default view) at the start of an experience, we use the attitudeOrientâs resetHeading() function, as explained in the Gyro-oriented Environments documentation.
In the project that weâve posted in this thread, weâve used the resetHeading() function it in the âshowâ script to ensure the view is set to its default value as soon as the experience is launched.
Note: If youâd like see that default view within Studio, you can use the âReset viewâ button in Studio:
- Yes, in general thatâs what we use raycasters for in headset mode.
A raycaster can be set up so that when it intersects with an (or multiple) object(s), an action -that can vary depending on the object intersected- is triggered.
To do so, youâll need to create a colliderTag for the raycaster and add it as a tag to each of the objects youâll use to trigger an action. You will then need to add an intersectionenter script to the raycaster in order to define the actions (e.g. playing a timeline, activating a state) that should be triggered depending on the object intersected.
You should find all the information you need in the Raycaster documentation.
- What youâre looking to do here could be done using a raycaster as well.
Feel free to ask if you have any questions.
Margaux
Thank you!! finally got the raycasters to sink in my brain
Iâm almost done my first experience, where a user can navigate through different room in a house!!
Very robust software!!!
thx!
RoomWalk.zpp (1.3 MB)
So thereâs the .zpp of what I have. Sorry it took so long. Real work took over my life.=P Yay production.
It all works pretty well for now as you can see from scanning the zap image I have up there. =) Itâs just not clean to me is all.
So I just discovered symbols, and I personally was hoping to use those as my rooms? So the idea would be build a symbol that is a photosphere with room button attachements, and I want to be able to throw in some content like things you can click on and read. Things that will activate videos⌠Yada yada. I was hoping that by having a âsymbolâ for each room, that I wouldnât need to change so many things in my current controller state under root. That and for design purposes, it would be easier to design a room without having to hide the other rooms in the current experience. Does that make sense? That way I can say âAh I want to edit room one!â I can open that symbol, do the edits, and not have to be concerned with the hidden trap door, the other 4 irrelevant buttons, and whatever information signs and videos I might be playing in the other 3 rooms.
Now, I havenât implemented /any/ of this in the program I just uploaded for you. It was just a thought as to how to make it a bit cleaner, and how to build it so I can edit each sphere individually without distractions from the others.
Yes, implementing your project using a subsymbol per photosphere would work as well.
I went through the 360 photosphere tutorial and created the project. Only problem is when I view in VR mode the Left and Right screens are flipped so the VR mode is unusable. I must have made a mistake along the way. Any suggestions for being able to flip the left and right screens so it works well with VR googles. Thanks in Advance.
Hi @rickgrandall,
You may need to use states to set the orientation of your content. This way youâll be able to specify âwhich way upâ the content should be.
Hi ,
I was also trying the photosphere example using this reference. I made it to the end as well, there are two photospheres - 1 & 2 placed at a distance from one another. Both of them have a button inside of them which transitions the SphereGroup so that the wanted sphere is at origin and thus provides correct view. I was able to do this along with the VR button implementation where clicking on it turn the experience for VR headsets. All this is working fine as expected when Iâm using Zappar App but the VR button isnât working when Iâm using it via browser. What could be the issue & how to resolve. Thanks.
