There’s any example with zappar+a-frame with videos? If it’s possible with multitracking images.
I’m working with this code but it’s not working…
<script> window.onload = function() { AFRAME.registerComponent('videohandler', { init: function () { var marker = this.el; this.vid = document.querySelector("#vid1"); marker.addEventListener('markerFound', function () { this.vid.play(); }.bind(this)); marker.addEventListener('markerLost', function() { this.vid.pause(); this.vid.currentTime = 0; }.bind(this)); } }); </script> <a-scene> <a-assets> <a-asset-item id="target-file" src="myTarget.zpt"/> <a-asset-item id="target-file2" src="myTarget.zpt"/> <a-asset-item id="target-file3" src="myTarget.zpt"/> <video src="CAM_03_640.mp4" preload="auto" id="vid1" response-type="arraybuffer" loop crossorigin webkit-playsinline autoplay muted playsinline> </video> </a-assets> <a-entity zappar-image="#target-file"> videohandler <!-- PLACE CONTENT TO APPEAR ON THE IMAGE HERE --> <a-video src="#vid1" position='400 0 -450' rotation='90 0 180' width='640' height='480' > </a-video> </a-entity> <a-entity zappar-image="#target-file2"> videohandler <!-- PLACE CONTENT TO APPEAR ON THE IMAGE HERE --> <a-video src="#vid1" position='400 0 -450' rotation='90 0 180' width='640' height='480' > </a-video> </a-entity> <a-entity zappar-image="#target-file3"> videohandler <!-- PLACE CONTENT TO APPEAR ON THE IMAGE HERE --> <a-video src="#vid1" position='400 0 -450' rotation='90 0 180' width='640' height='480' > </a-video> </a-entity> <a-entity camera zappar-camera></a-entity> </a-scene>
This is correct?
For chromakey videos add this in your head tag:
<script src="https://unpkg.com/aframe-chromakey-material/dist/aframe-chromakey-material.min.js"></script>
Try this: Playing video with chromakeys
You need not put window.onload function when u already have register component
try without the onload function also you should use the Zappar visible and non-visible component that actually track the image refer documentation : https://docs.zap.works/universal-ar/web-libraries/a-frame/image-tracking/
onload function is for play/stop video when image is tracked/detected. Is not needed? Zappar do the play button action automatically?
Yes you can do the .play() function inside the zappar visible function.
Here is a small glitch to refer, image target is inside the project : https://glitch.com/edit/#!/transformx-card
