Hi! I’m experiencing this same issue. I’ve prepared the video as shown in the alpha video tutorials, and when I import it into Zapworks everything seems to be as it should be, but when I start the process with the transformed texture, the texture fits the video into a square and cuts off the ends. I’ve tried it with both 1920x540 and 3840x1080 sized videos. If I change the scale I can move the image around but can’t fit it all into the square at once because it is supposed to play at 16:9.
Is it possible for me to change the transform texture to fit the aspect ratio of how I want the video to show, or should I render my videos again taking into account that they have to fit into a square, or is there something else I can do to fix this?
Realy relieved someone else has been having a similar issue, I thought I was going nuts because none of the tutorials I’ve found mention this.
Another problem I’m having: when I preview the finished project, it always opens in landscape, even if I’ve changed it to portrait inside Zapworks.
