Hello there!
I’m struggling to get my hands on the live camera texture in A-Frame, so that I can use it as a texture in my scene (end goal is dynamic environmental reflections by building a dynamic cubemap).
I created a new component called cubeMapRealtime attached to a simple primitive in my scene, and my experimentations so far are in this kind of mood:
const cubeMapRealTime = {
schema: { },
init() {
var camTexture = new THREE.Texture();
const refMat = new THREE.MeshBasicMaterial({
side: THREE.DoubleSide,
color: 0xffffff,
map: camTexture,
const staticTexture = new THREE.TextureLoader().load('https://www.matthughes.info/blog/content/images/2019/02/helping-hands-lkg.jpg');
var camEl = document.querySelector('#myCamera'); // this id is attached to my camera entity in the A-Frame scene
console.log("Camera entity:", camEl);
camTexture = camEl.getObject3D('camera').backgroundTexture; // this is where I miss something
var mesh = this.el.getObject3D('mesh');
mesh.material.map = camTexture;
export {cubeMapRealTime}
(the above code is stripped down to the sole part for fetching the camera texture)
I can see from the camera.js definition under zappar-threejs-for-aframe that there is a “backgroundTexture” meant for this use but it seems I’m wrong on how to access it; probably not making my way correctly from the different encapsulations through the different Three > AFrame > Zappar cameras.
Can someone point me in the right direction?
Thomas
