VideoTexture on a 3D object
I know I can assign a VideoTexture to a plane, using its “materials” property.
Problem : I would like to assign a VideoTexture to a custom geometry (imported pod file), but this kind of node does not have a “materials” property.
The goal is to have something that behaves like an animated texture (mapped in UV), for example to simulate a light movement on a car.
How may I do that ?
Thanks.
I don’t know if you can do video but you can change the materials on a pod file. If you use a time line you could make it look animated.
This may help as well.
Thank you Steve.
