When you start the application with panorama, you start facing a certain position. This position is always the same whenever you start, you always start facing the same part of the scenario. From there you can rotate the phone and see other parts of the scenario. At a certain point, I’d like to force reset the part of the scenario being seen to what is was initially, as if the user just scanned the zapcode and started the app again. How can I do this?
Hello, does someone answer you ?
My problem is quite the same.
I would like to set the initial panorama position.
A weird thing : when the user click the “reset rotation button”, the position is not the same as the beginning.
Help !
