Play video fullscreen immediately
I’d like to start playback in absolute full screen immediately on load.
@al.hodgson
Full-screen streaming video
The Zappar platform utilises the operating system’s underlying video support to stream full-screen video. The video must be hosted at a globally accessible URL. The following format is recommended for consistent playback across a range of devices and network connections:
MP4 at or around 640px by 480px
“Web-optimized” with the index at the start of the file
Audio 22.05 kHz mono at 128 kbps
Video should not exceed ten minutes in length.
Compatible full-screen video is launched from a script using the following syntax:
Z.device.playFullscreenVideo(“http://…”);
Thanks Steve, I’ve just started with Zappar, and only used the Zapworks Designer. I’ll have to delve into Zapworks Studio!
@al.hodgson
Are you looking at doing it in Designer or is Studio ok?
If it can be done in designer it would be a bonus!
Sorry, I don’t do much in Designer. But you can set the video size and then set to play on start. But looks like only for uploaded videos.
ok, I will experiment. thankyou
