i have tired with more than 5 developer to install zapworks studio.
in 5 differents system, and all of them have MSVCP120.dll
can not isntall the studio.
and when 1 some try to solved this issue… after solved it… when try to puplish the project, the studio crash !!!
Hi There,
We’ve had a few people run into the ‘MSVCP120.dll is missing’ error regarding missing the necessary Visual Studio runtime libraries, but it has always been resolved by following the steps in this article - https://support.native-instruments.com/hc/en-us/articles/209571689-Windows-Error-Message-Missing-MSVCP120-dll-File
For the crash you’re experiencing it’s best if you send us more information directly to support@zappar.com. Information on your machine and it’s OS along with the exact moment it crashes and any crash information the system might provide is very useful
Hello eliaskhs,
I had the same problem, Downloaded the file from https://fixdll.net/msvcp120, Worked fine for me.
Hope that helps,
Sameer
The dll files creates the problem when these are missing from the system and are not installed, so first you have to download MSVCP120.dll and installed it then the issue will definitely gone.
It is a common problem where msvcr140.dll becomes corrupted because of an update. Just Google for it or use this instruction https://techloris.com/msvcr120-dll-is-missing/ also run all available windows updates.
How about installing a DLL file on your hard drive it is easy to install. All you need to do is copy the file and paste that file to C:\Windows\System32 and install it. If it already exists in your drive while you run a program it will prompt a pop-up asking you to install it. If it doesn’t work try a step by step help on how to fix msvcp120.dll missing file error?
