My goal is to get a video inside a hole in the wall. Here is what I get so far :
I am streaming a video, using the VideoPlayer node. It works all right.
I am masking several 3D objects, using a Square Mask node. It works all right.
The problem : I would like my video to be hidden by the Square Mask, but I can’t find any way to make it work.
The VideoPlayer node does not have a “layerMode” attribute (so it can’t be set to “test_3d”).
Do you know a solution ?
Thanks.
