Look at behavior + Z.Vec3 and Z.Mat documentation
Hey,
Any possibility of providing some docs (or hints) for functions in Z.Vec3 and Z.Mat? I’m especially interested in Z.Mat.createRotationMatrix() and Z.Mat.anglesFromRotationMatrix().
I’m trying to build up a ‘look at’ function for rotating objects towards a specified point. I’ve made a heading vector from the objects current Euler angles and another one pointing towards my target point. If I’m not entirely mistaken, I can use atan2 to get the required rotation angle and define the axis to rotate around with a cross product. My problem lies in applying this angle and rotation-axis to the Euler angles of my zappar object.
I was wondering if the Z.Mat functions could help me with this issue. Math certainly isn’t my strong suit but I still feel like I might be fairly close with this. Any help would be appreciated!
Hey Ero,
Good catch, look like we missed them when documenting.
While we work on doing so the platform team provided some descriptions below which will hopefully help:
// reference: http://www.euclideanspace.com/maths/geometry/rotations/conversions/angleToMatrix/index.htm
matrixFromAxisAngle(axis, angle) {
	var c = Math.cos(angle);
    var s = Math.sin(angle);
    var t = 1.0 - c;
    var m00 = c + axis[0]*axis[0]*t;
    var m11 = c + axis[1]*axis[1]*t;
    var m22 = c + axis[2]*axis[2]*t;
    var tmp1 = axis[0]*axis[1]*t;
    var tmp2 = axis[2]*s;
    var m10 = tmp1 + tmp2;
    var m01 = tmp1 - tmp2;
    tmp1 = axis[0]*axis[2]*t;
    tmp2 = axis[1]*s;
    var m20 = tmp1 - tmp2;
    var m02 = tmp1 + tmp2;
    tmp1 = axis[1]*axis[2]*t;
    tmp2 = axis[0]*s;
    var m21 = tmp1 + tmp2;
    var m12 = tmp1 - tmp2;
    return [m00, m01, m02,
            m10, m11, m12,
            m20, m21, m22];
normalize(vec) {
	return Z.Vec3.scalarMultiply(forwardVec, 1.0 / Z.Vec3.magnitude(forwardVec));
cross(vecA, vecB) {
	var x = vecA[1] * vecB[2] - vecB[1] * vecA[2];
	var y = vecA[2] * vecB[0] - vecB[2] * vecA[0];
	var z = vecA[0] * vecB[1] - vecB[0] * vecA[1];
	return [x, y, z]
lookAt(forwardVec, targetVec) {
	// normalize
	var forward = normalize(forwardVec);
	var target = normalize(targetVec);
	// compute the rotation axis
	var axis = cross(forward, target);
	// compute the angle
	var cosTheta = Z.Vec3.dot(forward, target);
	var angle = Math.acos(cosTheta);
	// compute the rotation matrix
	var rotM = matrixFromAxisAngle(axis, angle);
	// get the Euler angels
	return Z.Mat.anglesFromRotationMatrix(rotM);
// let's say, the object's position is objPos with the defined forward vector as objForward, and the look at target's postion is targetPos, then call
var angles = lookAt(objForward, Z.Vec3.subtract(targetPos, objPos));
Cheers,
Hey Mark,
Thank you! That helps a lot.
I managed to implement this behavior with simpler math, but with separate transform groups for pitch and yaw. I think what you posted makes things cleaner though so I’ll probably switch over to that.
I used this behavior to implement hacky line drawing between points and it’s working quite well. Probably not the best performance-wise, but it works for now. Now this made me think of more feature requests. :wink:
Thanks again!
