I am trying to visualize a model that was generated from protein data (https://www.rcsb.org/) in ZapWorks, but ran into the following problem.
I have triangular meshes generated (tried both POV and OBJ files) and they both upload fine. But the texture file does not show up on the model. I tried applying different texture files (including from existing ZW models), but for some reason they do not work in combination with molecular models.
Have you encountered such problem and what might be the reason/solution for it?
I prepared some POD files (3D files.zip (1.5 MB)) so you can compare the behavior of the exact same texture (Heart_CM_TEXTURE_v3.png) applied to two different 3D models, one is a regular mesh (Heart_texture.pod) and works perfectly, while the other one is a mesh created from molecular data (3dtest_texture.pod) and doesn’t display any texture.
Thank you!
