Help in particle
I would like to know if you have some examples of how to create particle effects in ZapparStudio?
Particle effect - snow or rain
Hi There,
There is no built in particle effects at this point in time in Studio, however, our in-house creative team has built one for use across their projects which we’re happy to share with you :slight_smile:
The project below has a plane in it acting as a button that when pressed activates some code that randomly positions and moves a collection of star burst images. You can enter the ‘Glitter Particle’ subsymbol if you want to dig deeper into the implementation.
Particle Effect.zpp (283.4 KB)
Hope this is useful :slight_smile:
Exporting fire & smoke
Hay Mark,
I’m playing with your Particle Effect and I’m loving it!!
I have a question. When I run your code it doesn’t change the pattern each time I press the button.
How would I get it to do that?
Hi Steve,
The plane just calls the activate function, it only randomizes one time at the begging and then uses those values each subsequent time. You can move the for loop inside the activate function in the particleCode script to randomize everytime. So it would look like the following:
var no_particles = 15;
var d = 1;
var particles = [];
//create the particles and push them to the <particles> group
var plusOrMinus = function(){
	if(Math.random() > 0.5){
		return 1;
	else{return -1;}
export function activate(){
    for(var i = 0; i < no_particles; i++){
	// create the particle and push it into the array
	particles.push(Z.Symbol("Glitter Particle"));
	// then push that particle to the 'particles' group
	symbol.nodes.particles.push(particles[i]);
	// pass random parameters to that particle
	var x = (Math.random() * d) * plusOrMinus();
	var y = (Math.random() * d) * plusOrMinus();
	var z = (Math.random() * d) * plusOrMinus();
	var scale = Math.random() * 0.4 + 0.4;
	var speed = 1 + 0.5 * Math.random();
	particles[i].nodes.code.set_x(x);
	particles[i].nodes.code.set_y(y);
	particles[i].nodes.code.set_z(z);
	particles[i].nodes.code.set_scale(scale);
	particles[i].nodes.code.set_speed(speed);
	for(var i = 0; i < particles.length; i++){
		particles[i].nodes.code.activate();
Edit* I’ve just realized that this is creating a new set of particles each time which is bad as it will build up and slow your phone down. What you will want to do is create your pool of particles outside of the activate function and then change their x,y,z, scale and size inside activate.
Creating instances of object
Thanks Mark,
I was thinking I would have a problem with build up of new sets. I didn’t see how to remove a new item. Can we? or would I have to remap x,y,z? I’m looking at using this on other things later.
We don’t have any garbage collection in Studio at the moment so it’s best to just use a pool of objects. It’s done easily enough by moving the random number generation to the activate function but keeping the creation of the particles to the for loop that runs once:
Thank you Mark.
I’m looking at doing something with moving rocks but I did’t see how to clean up things.
What would be the best way to track how many pooled objects I have. (for debugging)?
Thanks for all your help!
Hi Steve,
Once constructed there’s no way at the moment for “deleting” the memory used so it’s not possible to do the traditional clean up of removing objects.
The best thing to do is create an array of the objects like we do in the example above with the particles[] array. You can use the .length property of the array to tell how many objects you have.
#9
Thank you!
I was playing with the Particles code and found it had colored one. So I added your code and a random color code to it:
var d = 1;
var particles = [];
//create the particles and push them to the group
return 1;
else{return -1;}
// Color pick send color number 0-4 if more then 3 change
var color = function(){
var c = 0;
c = Math.floor(Math.random() * 11);
while (c > 5)
return c;
particles.push(Z.Symbol(“Glitter Particle”));
// then push that particle to the ‘particles’ group
particles[i].nodes.code.set_color(color());
#10
This is -almost- exactly what I’m trying to do, and I’ve been diving into it to find out how to change it to suit my needs.
What I’d like to do is instead of having the particles radially move outward from their random position a random distance away from 0,0, but in the same plane, I’d like them to move -up- (perpendicular from the plane). I can’t seem to find this in the code, the speed is how fast it goes, not in which direction, so I figure this is ‘hardcoded’ within the Glitter Particle.
I can’t find how to change it though. Can you give me some pointers?
#11
Hi Mark,
In the ‘particleCode’ script node within the zpp you should see three variables: x, y and z.
These variables are currently being assigned a randomised value through the Math.random() function, and then being passed in to the set_x, set_y, and set_z functions (exported from the ‘Glitter Particle’ subsymbol) later on in the script.
By changing these values, you can change the direction that the particles will be travelling towards.
#12
Thanks, Seb!
I assumed those were the starting points of the particle. I Should be able to figure it out now :slight_smile:
#13
I have tried my own particles system, “water” style… :slight_smile:
#14
Very cool!
#15
Here it’s the zpp file for those who want to play with it. Code similar from Mark’s, but the nodes are managed with JS objects. Everything is inside the node “code”. Enjoy! :slight_smile:
Particles.zpp (370.4 KB)
#16
Many thanks!
Cheers!
#17
This is great, thanks for sharing! Are you looking to use this is a project soon? Love to hear a little more about what your plans are :slight_smile:
#18
Glad you like it! :slight_smile:
Yes I’m using this kind of code for a small game I’m working on - nothing serious, just a way to learn more about Studio. In fact, I’m starting to consider Studio as a kind of IDE pour AR/VR JS application! :slight_smile:
