Can I design my own buttons in designer?
Yes, I do that quite often to match corporate branding. Import them as an image and then give them an action under properties.
Wonderful ! Thank you:slight_smile:
Same question so using the existing thread.
How to import (or use other) button styles into the new Designer tool?
Hi @arnon.ilani,
@mike.peates had the exact right idea, and you can do the same with Designer (Beta) too!
If you have a particular graphic that you would like to use as a button, simply import it to your Designer canvas as an image component. You can then use actions on that image to make it act like a button.
Have a fantastic day!
Francesca
