I currently have a scene that has a plane flying around.
Is there a way to attach the audio to an object and have it get affected by distance - ie. when the plane is in the distance, its quiet, and vice versa when the plane is closer to the screen?
Hi James,
You can grab the position of a node using the .position()
function.
You can use the returned position values and add some code that will affect the volume of the audio using the .volume()
function.
